Danny,
Thanks again for all your help. I tried what you said, and it did work, but
how do I now get an accurate proposed surface, volumes, contours, etc.
through these areas (see attached image)?
Is my best bet to export the corridor to a surface and try surface
manipulation? I haven't really tried editing a surface yet, but I'll try
this route tonight and let you know how I make out (are we sure there isn't
just a simple toggle :-).
Thanks Danny!
-Seth
wrote in message
news:4985758@discussion.autodesk.com...
Seth,
I did verify that the targetDTM within the logical naming does add an entry
or two each time you add a region. It works just like the alignments and
profiles in the logical naming in this case. That is a good sign so you
should be able to do what we are discussing her. As it is the weekend, I
don't have the time to play with it now, but provided you are able to
control the stationing of the region for the area where there are crossings,
when that "TargetDTM" entry is added to the logical naming, you want to
ensure it is NOT daylighting to the existing ground surface, you can do this
by clicking on the Object Name column and making sure the TargetDTM is set
to None
