AutoCAD Civil 3D General Discussion
Member
vinco
Message 1 of 11 (511 Views)
Accepted Solution
Corridor Materials List and Volume Report
511 Views, 10 Replies
11-06-2013 06:53 AM
I am trying to get a material volume report for a corridor structure. The overall dirt cut fill is working, but the pavement and base keeps showing up as zero.
I started with the surfaces made, (perhaps that’s the problem,) I made an alignment, used an assembly, made a profile, and sample lines, made the corridor. Tthe assembly draws  in the cross sections, but the materials report shows zero in the pavement and stone.
All help appreciated.
*Expert Elite*
Jay_B
Message 2 of 11 (498 Views)
Re: Corridor Materials List and Volume Report
11-06-2013 07:10 AM in reply to: vinco
Have you created a "Quantity Takeoff Criteria" that includes the Corridor Shape "Material Names" and use the "Quantity Type"Structures"?
Jay
C3D 2014 SP2
Win 7 Professional 64 Bit
New Member
mjgc11
Message 3 of 11 (490 Views)
11-06-2013 07:16 AM in reply to: vinco
I have the same problem, when i try to calculate the volumen of the base, sub-base and pavement structur, the sections views only show a hatch in one side of the section, and the volumen tables show wrong results. The problem began since i instal de last service Pack product C3D. Anyone can help me to solve this problem.
*Expert Elite*
Jay_B
Message 4 of 11 (480 Views)
11-06-2013 07:21 AM in reply to: mjgc11
The OP didn't specify a version but your referring to 2014 SP1 and this is a known issue with Service Pack 1.
I have created a Support Case for this and there's another thread started today for this issue.
AutoDesk told me the only fix for this at this time is to uninstall SP1 as it worked in HF1. :smileymad:
Jay
C3D 2014 SP2
Valued Mentor
fcernst
Message 5 of 11 (478 Views)
11-06-2013 07:22 AM in reply to: mjgc11
Compute Materials Volume is now broken. Please see link below:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Confirmed-Defect-Structural-Material-Volume-S...
Fred Ernst, PE
C3D 2015
Ernst Engineering
www.ernstengineering.com
Member
vinco
Message 6 of 11 (453 Views)
11-06-2013 07:49 AM in reply to: vinco
I have "structures" picked in the "edit materials list".
Is there another place I need to set it up?
 c3d 2012 SP2
Member
vinco
Message 7 of 11 (437 Views)
11-06-2013 08:20 AM in reply to: Jay_B
I set it up in Quantity takeoff, but the materials still report zero for the pavement and base.
*Expert Elite*
Jay_B
Message 8 of 11 (424 Views)
11-06-2013 08:37 AM in reply to: vinco
Do the structure names in Subassemblies used match the values in the QTO criteria?
Did you choose import another criteria & select your Materials list criteria for the calculation?
Can you post the drawing for someone to look at it?
We didn't use 2012SP2 here because it was generally unstable out a month or less & replaced by 2012SP2.1
2012SP4 is current patch available, If you're sure your doing everything correctly you may want to update to the latest SP & see if that helps. When using 2012 SP2.1 & SP 3 the material volumes worked fine here.
Jay
C3D 2014 SP2
Member
vinco
Message 9 of 11 (412 Views)
11-06-2013 09:07 AM in reply to: vinco
Impoting another criteria fixed part of the problem. When I creat a table, the quantities are now there, but when I creat the cross sections they still say zero.
Valued Mentor
fcernst
Message 10 of 11 (409 Views)
11-06-2013 09:12 AM in reply to: Jay_B
They called that a fix?
This would put the Corridor Section Editor back to the defective state that it was released as in Civil 3D 2014.
Fred Ernst, PE
C3D 2015
Ernst Engineering
Announcements
Need installation help?
