AutoCAD Civil 3D General
Distinguished Contributor
Message 1 of 5 (245 Views)
Corridor Gap
245 Views, 4 Replies
12-13-2012 12:00 AM
Can anyone explein to me why gaps created where the regions of intersections joins? The daylight feature line stop connecting . See the attached picture. How i can resolve it?
sboon
Message 2 of 5 (242 Views)
Re: Corridor Gap
12-13-2012 12:04 AM in reply to: nikoue
You should be able to grip edit the corridor region boundaries to extend them so that they touch.
Message 3 of 5 (237 Views)
Re: Corridor Gap
12-13-2012 12:10 AM in reply to: sboon
They seem to touch. I must overlap the regions to connect them. And if i done that the intersection and corridor needs to update. When i update the gaps came back.
LisaPohlmeyer
Message 4 of 5 (216 Views)
Re: Corridor Gap
12-13-2012 05:51 AM in reply to: nikoue
Although I like the intersection tool for adjusting profiles, I don't like how it creates the return alignments, we get gaps as well. Our work around to this is to modify the return alignments to have 10' tangent sections on each end.
Lisa Pohlmeyer
C3D 2012 SP4, holding off on C3D 2014
Please use "Accept as Solution" if this solved your issue.
Message 5 of 5 (192 Views)
Re: Corridor Gap
12-13-2012 09:10 AM in reply to: LisaPohlmeyer
The gaps usually appears between the curb return and the full section region. How it will help to modify the return alignment in the end?  The problem is not appear in the end. Also i want to ask you if you modify only the return alignments or you modify the offset alignments too? After your modifications you rebuild the corridor or you update regions and rebuild corridor? If you done the second the modifications still remaining?
Thank you
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
