I am having an issue where I have set through my codes that i do not want to view the frequecy lines in my corridor. It is displaying right but when i go to print all the frequency lines print. the attached images show my screen of what i am looking at and the other is a pdf of what prints.
thank you
Tom Oines
Aberdeen, South Dakota
Solved by tmoines. Go to Solution.
I think i discovered what may be the issue. I went and made a simple corridor with one intersection, turned my codes to no display and it printed just find. I wonder if the size of my other corridor is creating the problem. I am running 3d 2013 64 bit service pack 2, my computer is running windows 7 w/ 2 2.26 GHz processors with 12 GB of RAM. The base drawing file is 6MB. thinking that this might be the cause i have tried to start a clean drawing x-ref in the base model but it still prints. Any Ideas of what I could try next.
Thank you,
Tom Oines
Sorry,
I figured out that my base link code was set to a froze layer, because initially i thought i could set them to a no print layer, but after it printed anyway i froze that layer, so it didn't display but it would print. i thawed that layer and saw i still had a displayed link and then went back into my codes and shut that to no display and now it works.
