I cant seem to target a corridor FL and keep it linked to the corridor. Is this the expected behavior? I would think you should be able to, no? For that matter I would think you should be able to pick the cooridor link directly, no?
Your Name
Solved by castled071049. Go to Solution.
If the corridor flowline is in the same corridor as the targeting assembly, then it will not work. You can only target corridor flowlines that are in different corridors than your targeting assembly.
Does that make sense? It sounds convoluted when I read it back.
Yes it does make sense.
When I was writing my post, a little voice in the back of my head kept saying ...."circular reference, joe. it's a circular refer....."
Your Name
