IS it possible in areas such as the image attached, in daylight between two alignments to interact with each other (Similar to grading tools)
At the moment, i use a feature line on the edge of the pavement and use grading. however this slows the computer down a lot.
ANy ideas
Thanks in advance.
Solved by sboon. Go to Solution.
You could also use two separate corridors, and have one of them target the surface created by the other one.
