Civil 3D Forum
Corridor Datum/Formation Surface question
4 REPLIES 4
neilyj666
867 Views, 4 Replies
When using an assembly with vertical edges, what happens when a Corridor datum surface is extracted i.e. vertical edges are not permitted in triangulated surface??
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
4 REPLIES 4
Alfred.NESWADBA
in reply to: neilyj666
that should not be done with modifying the intervals of your (normal) contours. For creating contours with specific (user-defined) elevations you should look into DGM-properties and "Analyse" for "User-Specified Contours"
See >>>help<<<
HTH,  - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
mathewkol
I'm not sure what Alfred's getting at but if you did nothing, yes you'd have a problem. The syrface would triangulate to the next point outwards with the "Datum" code.
For all datum surfaces it's best to toggle the "Bottom links" option in the Overhang correction column of the corridor surfaces dialog.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
neilyj666
in reply to: mathewkol
I do that as a matter of course, but in the screenshot that would mean a vertical face at the edges??
mathewkol
As near as you can get with a TIN.
Matt Kolberg
Rail Community
