AutoCAD Civil 3D General
Member
Message 1 of 2 (84 Views)
Corridor Creation Issues
84 Views, 1 Replies
07-07-2008 11:09 PM
I am a new user to Civil 3d. I am trying to get a basic output and am having difficulty despite following 'Mastering Civil 3d' and reading forums.
I am trying to create a surface from contours, Create an alignment, a profile, a assembly and create a contour. I have simplified the project to the most basic parameters in order to eliminate as many issues as possible.
Firstly I have 8 contour polylines with 1 to 8m heights assigned to them. I create a surface from this with a border and get a 3d image and triangles that seem accurate.
I then place an alignment running in a straight line running up the hill in the middle of the surface.
I then create a surface profile from that alignment and create a profile view (although this view is vary large it accurately displays the change in height over the alignment)
Everything seems fine up till now
Now I create a simple corridor. I only have one surface, alignment, profile and profile view to choose from so I choose them.
I have also tried combinations of setting the logical values or not. (Including setting them for surface only, and setting them for all but TARGET HA as well as setting everything or nothing)
When i complete the process a message appears saying i have "bad value" or "intersection value not found" at what I must imagine is every point it tries to create the assembly.
The corridor appears on the surface but it is not integrated into it at all. It is like it is sitting through the finished surface.
I would really appreciate any help that you could provide with this as i have explored most options i can think of and am finding it very frustrating
I have included a zip of the file if that helps
Firstly i
*Jeff Mishler
Message 2 of 2 (84 Views)
Re: Corridor Creation Issues
07-08-2008 12:08 AM in reply to: bd23
You need to set the target surface for the daylights.
"bd23" wrote in message news:5975534@discussion.autodesk.com...
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
