AutoCAD Civil 3D General
francisco_bobadilla
Message 1 of 4 (168 Views)
Corridor Code Set - Feature Line Selection
168 Views, 3 Replies
11-27-2012 09:22 AM
Is there a way to be able to choose a desired feature line when extracting from a corridor?  For example, when subgrade and finished grade are on top of each other, it seems subgrade is always coming as default for extraction.  I'm not getting the option to select the desired point code as usual for some reason.  The best way I found is by turning off the subgrade feature line from the corridor properties, which is a bit tedious.
Any help would be appreciated. Thanks
tcorey
Message 2 of 4 (166 Views)
Re: Corridor Code Set - Feature Line Selection
11-27-2012 09:38 AM in reply to: francisco_bobadilla
I think what we need to figure out is why you're not getting the dialog that shows you all the overlapping feature lines at the selection point.
I tried a few settings and I can't get it to not show the dialog.
Is this happening in just one drawing or all drawings? That would point me to either the drawing settings or the registry.
Tim
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
francisco_bobadilla
Message 3 of 4 (162 Views)
11-27-2012 10:01 AM in reply to: tcorey
Hi Tim,
All the drawings.  Keep in mind though, all of our assemblies are standard and we always use a company template for each drawing.  For some reason on other feature lines I do get the dialog box. Strange
tcorey
Message 4 of 4 (157 Views)
11-27-2012 10:18 AM in reply to: francisco_bobadilla
Oh, so you're getting the dialog most of the time, but just not on a certain feature line?
Are you sure you don't have a duplicate point code at that location? If you post the corridor we can take a look for you...
Tim Corey, Owner
Redding, CA
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
