AutoCAD Civil 3D General
neilyj
Message 1 of 11 (1,303 Views)
Corridor Boundary
1303 Views, 10 Replies
03-27-2012 08:55 AM
What's going on with this - I don't have an option for Daylight as a boundary.....using the same assembly as usual so I must be missing something very obvious but can't see it.......
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Distinguished Contributor
dibr0804
Message 2 of 11 (1,296 Views)
Re: Corridor Boundary
03-27-2012 09:03 AM in reply to: neilyj
I've had this before too, I just worked around it. What I did was create a polyline boundary by copying the surface with the border turned on and then exploding it. Then add the boundary that way..
Might want to offset the border by .1 or .01 or something like that too..
Valued Contributor
emelendez
Message 3 of 11 (1,264 Views)
03-27-2012 12:24 PM in reply to: dibr0804
dibr0804 wrote:
..... by copying the surface with the border turned on and then exploding it. ......
FYI....you can extract objects from a surface. Just set the style of your surface to show the border, then while you have it highlighted. in the context tab in the ribbon you should see extract objects.....use that to extract the boundary. then add it as you said. saves time and headache......
Edwin Melendez
AutoCAD Civil 3D 2013 Certified Professional
Certification No. 00319327
klugb
Message 4 of 11 (1,254 Views)
03-27-2012 01:16 PM in reply to: neilyj
Are you sure you have catches everywhere? I have seen this when there isn't enough topo.
Two options:
1) Add another baseline to your corridor so then you will get the option "Corridor extents as boundary" option. You don't need a region. Dynamic
2) Create boundary from corridor externally and apply to surface. Not dynamic.
Bruce Klug
AutoCAD Expert Elite
AutoCAD Civil 3D 2014 Certified Professional
Infrastructure Design Suite 2014 (SP1)
Testing Civil 3D 2015
Win 7 Pro, 64-bit
sboon
Message 5 of 11 (1,227 Views)
03-27-2012 05:02 PM in reply to: klugb
You have Daylight Fill as an option but not Daylight.  This suggests to me that you aren't creating the Daylight Feature line.  Is it checked on in the Feature Lines tab?
neilyj
Message 6 of 11 (1,206 Views)
03-28-2012 12:19 AM in reply to: sboon
This is the tab - as mentioned its the same assembly dragged in as usual from a tool pallette; never had a problem in the past with this.....GRRRRRR
neilyj
neilyj
Message 7 of 11 (1,184 Views)
03-28-2012 05:20 AM in reply to: klugb
Thanks for this Bruce - tried both and both worked fine
neilyj
Active Member
Malikawan
Message 8 of 11 (912 Views)
12-31-2012 04:48 AM in reply to: neilyj
I am new in civil 3d.when i prepare a corridor its boundary suddenly goes away.kindly guide me???
sboon
Message 9 of 11 (854 Views)
01-01-2013 10:50 PM in reply to: Malikawan
Please note - adding a new question to the end of an old thread which has already been solved is usually referred to as a hijack, and is considered to be impolite.  If you ask your question in a new thread I'm sure that someone will be able to help.
Active Member
Malikawan
Message 10 of 11 (843 Views)
01-02-2013 12:41 AM in reply to: sboon
ok really sorry steve actually new user
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
