Civil 3D Forum
Corridor Boundary
10 REPLIES 10
Message 1 of 11
neilyj666
4561 Views, 10 Replies
Corridor Boundary
What's going on with this - I don't have an option for Daylight as a boundary.....using the same assembly as usual so I must be missing something very obvious but can't see it.......
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
10 REPLIES 10
Message 2 of 11
in reply to: neilyj666
I've had this before too, I just worked around it. What I did was create a polyline boundary by copying the surface with the border turned on and then exploding it. Then add the boundary that way..
Might want to offset the border by .1 or .01 or something like that too..
Message 3 of 11
emelendez
@Anonymous wrote:
..... by copying the surface with the border turned on and then exploding it. ......
FYI....you can extract objects from a surface. Just set the style of your surface to show the border, then while you have it highlighted. in the context tab in the ribbon you should see extract objects.....use that to extract the boundary. then add it as you said. saves time and headache......
Edwin Melendez
AutoCAD Civil 3D 2013 Certified Professional
Certification No. 00319327
Message 4 of 11
klugb
Are you sure you have catches everywhere? I have seen this when there isn't enough topo.
Two options:
1) Add another baseline to your corridor so then you will get the option "Corridor extents as boundary" option. You don't need a region. Dynamic
2) Create boundary from corridor externally and apply to surface. Not dynamic.
Bruce Klug, P.E.
AutoCAD Expert Elite Alumni
AutoCAD Civil 3D Certified Professional
Civil 3D 2023.2.1
Win 10 Enterprise, 64-bit
Message 5 of 11
sboon
in reply to: klugb
You have Daylight Fill as an option but not Daylight.  This suggests to me that you aren't creating the Daylight Feature line.  Is it checked on in the Feature Lines tab?
Steve
Expert Elite Alumnus
Message 6 of 11
neilyj666
in reply to: sboon
This is the tab - as mentioned its the same assembly dragged in as usual from a tool pallette; never had a problem in the past with this.....GRRRRRR
Message 7 of 11
neilyj666
in reply to: klugb
Thanks for this Bruce - tried both and both worked fine
Message 8 of 11
Malikawan
I am new in civil 3d.when i prepare a corridor its boundary suddenly goes away.kindly guide me???
Message 9 of 11
sboon
in reply to: Malikawan
Please note - adding a new question to the end of an old thread which has already been solved is usually referred to as a hijack, and is considered to be impolite.  If you ask your question in a new thread I'm sure that someone will be able to help.
Steve
Message 10 of 11
Malikawan
in reply to: sboon
ok really sorry steve actually new user
Message 11 of 11
sboon
No problem - and BTW welcome to the board Smiley Happy
Steve
Rail Community
