AutoCAD Civil 3D General
*Expert Elite*
neilyj
Message 1 of 11 (1,222 Views)
Accepted Solution
Corridor Boundary
1222 Views, 10 Replies
03-27-2012 08:55 AM
What's going on with this - I don't have an option for Daylight as a boundary.....using the same assembly as usual so I must be missing something very obvious but can't see it.......
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2014 (mainly Civil 3D 2014 UKIE SP1 & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
Distinguished Contributor
dibr0804
Message 2 of 11 (1,215 Views)
Re: Corridor Boundary
03-27-2012 09:03 AM in reply to: neilyj
I've had this before too, I just worked around it. What I did was create a polyline boundary by copying the surface with the border turned on and then exploding it. Then add the boundary that way..
Might want to offset the border by .1 or .01 or something like that too..
Valued Contributor
emelendez
Message 3 of 11 (1,183 Views)
03-27-2012 12:24 PM in reply to: dibr0804
dibr0804 wrote:
..... by copying the surface with the border turned on and then exploding it. ......
FYI....you can extract objects from a surface. Just set the style of your surface to show the border, then while you have it highlighted. in the context tab in the ribbon you should see extract objects.....use that to extract the boundary. then add it as you said. saves time and headache......
AutoCAD Civil 3D 2013 Certified Professional
Certification No. 00319327
*Expert Elite*
Message 4 of 11 (1,173 Views)
03-27-2012 01:16 PM in reply to: neilyj
Are you sure you have catches everywhere? I have seen this when there isn't enough topo.
Two options:
1) Add another baseline to your corridor so then you will get the option "Corridor extents as boundary" option. You don't need a region. Dynamic
2) Create boundary from corridor externally and apply to surface. Not dynamic.
Bruce Klug
AutoCAD Expert Elite
AutoCAD Civil 3D 2014 Certified Professional
C3D 2014 (SP1)
Win 7 Pro, 64-bit
*Expert Elite*
sboon
Message 5 of 11 (1,146 Views)
03-27-2012 05:02 PM in reply to: klugb
You have Daylight Fill as an option but not Daylight.  This suggests to me that you aren't creating the Daylight Feature line.  Is it checked on in the Feature Lines tab?
*Expert Elite*
neilyj
Message 6 of 11 (1,125 Views)
03-28-2012 12:19 AM in reply to: sboon
This is the tab - as mentioned its the same assembly dragged in as usual from a tool pallette; never had a problem in the past with this.....GRRRRRR
neilyj
*Expert Elite*
neilyj
Message 7 of 11 (1,103 Views)
03-28-2012 05:20 AM in reply to: klugb
Thanks for this Bruce - tried both and both worked fine
neilyj
Active Member
Message 8 of 11 (831 Views)
12-31-2012 04:48 AM in reply to: neilyj
I am new in civil 3d.when i prepare a corridor its boundary suddenly goes away.kindly guide me???
*Expert Elite*
sboon
Message 9 of 11 (773 Views)
01-01-2013 10:50 PM in reply to: Malikawan
Please note - adding a new question to the end of an old thread which has already been solved is usually referred to as a hijack, and is considered to be impolite.  If you ask your question in a new thread I'm sure that someone will be able to help.
Active Member
Message 10 of 11 (762 Views)
01-02-2013 12:41 AM in reply to: sboon
ok really sorry steve actually new user
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
