Civil 3D Forum
Corridor Boundary fails with Super
13 REPLIES 13
Message 1 of 14
Neilw_05
483 Views, 13 Replies
When I apply superelevation to my corridor the boundary is not honored.
I found a similar post back in 2007 so it's been around for a while. That post didn't seem to have the solution.
Attached is a screen cap of the problem.
The corridor consists of a centerline with profile and edge of lane alignments (no profiles) for targets. The assembly consists of a left and right laneoutsidesuperwithwidening subassembly, nothing more. The surface is from the top link and the boundary is automatic using the ETW.
I know the problem is related to superelevation because when I remove it the behavior stops.
P.S. Is there a way to disable superelevation without removing the settings?
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
13 REPLIES 13
Message 2 of 14
sboon
in reply to: Neilw_05
Trying to recreate the problem here, but my drawing works fine.  Can you post your file?
What happens if you replace the subs with LaneSuperelevationAOR?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Message 3 of 14
Neilw_05
in reply to: sboon
I have a stripped down version of my file but it's still over 2 MB. I'll need to use a public file sharing service to make it available. Any suggestions?
Meanwhile I'll experiment with other subassemblies to see if it makes a difference.
WIN 10 64 PRO
Message 4 of 14
sboon
I like Dropbox for this sort of thing.  It's also useful for sharing files between your own devices (phone, home computer, office etc.)
Steve
Message 5 of 14
Neilw_05
in reply to: sboon
I'm unable to use Drop Box in our network environment.
Our systems are locked down so I can't install any apps. It has to be a totally web based service.
Any other suggestions?
WIN 10 64 PRO
Message 6 of 14
Neilw_05
After switching out the subassemblies to LanesuperelevationAOR, it appears the problem has gone away. Even when I go back to the original LaneOutsideSuperWithWidening subassemblies the boundaries work, so there was something C3D didn't like in that first configuration.
I've learned one good rule for troubleshooting: try switching out subassemblies
I'll consider this resolved.
I'd still like to know if I can temporarily disable superelevation.
WIN 10 64 PRO
Message 7 of 14
troma
I think with Google Drive you have the option to upload with an app or just from the web with no app.
Mark Green
Working on Civil 3D in Canada
Message 8 of 14
Neilw_05
in reply to: troma
Does Google Drive allow sharing via a link in the forum? I'd like to find a solution that doesn't require installing apps, email addresses, permissions or user accounts.
WIN 10 64 PRO
Message 9 of 14
troma
Never tried it, but I thought I'd seen someone else do it.
Mark Green
Message 10 of 14
BrianHailey
Let's try it. Here's a tutorial drawing I uploaded to my google drive.
https://docs.google.com/file/d/0B1dvb7G0tMGcTjQteFh2OWpQVmM/edit?usp=sharing
I did have to change the permissions on it so anyone with the link could access it.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 11 of 14
Neilw_05
in reply to: BrianHailey
That worked for me Brian.
There seem to be quite a few services out there. Some apparently don't require accounts, permissions etc. such as SendUit (it reported a technical problem when I tried it). Do you think Google Drive is easy to use?
WIN 10 64 PRO
Message 12 of 14
Jay_B
I'm able to save the file.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 13 of 14
BrianHailey
Message 14 of 14
Neilw_05
That looks simple enough.
I'm waiting to see if SendUit comes back online as it doesn't appear to require any account or file management at all. Meanwhile Google Drive should do the job.
WIN 10 64 PRO
Rail Community
