Civil 3D Forum
Copying Surfaces
14 REPLIES 14
Message 1 of 15
7126 Views, 14 Replies
Copying Surfaces
Is there a way to copy a surfacce?  I want to make major changes to a surface I have created but there is the possibliy of utiltiizing the existing sruface.  I want to copy the surface and then make changes.
14 REPLIES 14
Message 2 of 15
awood
You can just use the AutoCAD Copy command with a basepoint of 0,0
HTH
AWood
Message 3 of 15
BrianHailey
Or you can create a new surface and paste the original into and then modify away. If the original changes, the new one will change as well when rebuilt. Depending on what you are doing, either option is viable.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 4 of 15
neilyj666
in reply to: BrianHailey
Does using the Copy method make the copied surface non dynamic to the original??
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 5 of 15
BrianHailey
in reply to: neilyj666
Correct. The new is not dynamically linked to the original. It is, however, dynamically linked to the data that was used to create the original at the time of the copy. If you added breaklines to the surface, copy the surface, change the breaklines, both surfaces will update. If you add additional breaklines to the original surface after the copy, only the original will change.
If you create a new surface, paste the original in it, then the original is being used as data in the new surface. If the original surface changes, the new one will change.
GEI Consultants
My Civil 3D Blog
Message 6 of 15
mathewkol
I might be inclined to make a copy of the DWG and make edits there. Not always an option but it may work for you.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 7 of 15
arturopolanco
in reply to: awood
best options, is copy with base point in coordinate 0,0,0
Arturo Polanco
AEC Solutions Specialist - Civil Infrastructure
Web | Moodle | Youtube | Instagram | Twitter | Facebook | MeWe | VK
Message 8 of 15
BrianHailey
in reply to: arturopolanco
Easiest way to do that is grab the surface and type CO<enter><enter><enter>
That will copy an object in place. The CO<enter> runs the copy command on the surface you have selected. The second <enter> uses the option of Displacement. The third <enter> uses the default displacement of 0,0,0. I didn't know about this little trick until I started teaching AutoCAD and Civil 3D personally.
GEI Consultants
My Civil 3D Blog
Message 9 of 15
EddieMoreno
How can you 'unlink' the objects that are dynamic? I have two surfaces that I created, one copied from the other, and I need them independent of one another. Unfortunately, as you pointed out, I cannot make any edits to the original's line work.
Message 10 of 15
ChrisRS
in reply to: EddieMoreno
As @mathewkol said in post 9, you need to work each surface in its own drawing. The definitions will not be linked.
Christopher Stevens
Message 11 of 15
ChrisRS
As @mathewkol said in post 6, you need to work each surface in its own drawing. The definitions will not be linked. I
Christopher Stevens
Message 12 of 15
EddieMoreno
in reply to: ChrisRS
Unfortunately, I had already made the copy of the surfaces, but yes - working the surfaces in their own drawings works. Since Ive already done the do, copying the surface objects (from the copied surface that has the linked objects) separately into a new drawing and recreating the surface would work. That way it keeps its editable properties via the objects. Would you agree or am I over thinking it? 😕
Message 13 of 15
ChrisRS
I agree
I would probably take a brute force approach.
Drawing-1 has Surface-1 and Surface-2.
Save Drawing-1 as Drawing-2.
Delete Surface-1 from Drawing-2.
Delete Surface-2 from Drawing-1.
In the future:
Drawing-1 has Surface-1.
You realize that you want a back up copy of Surface-1.
In Drawing-2,  rename Surface-1 to Surface-2.
Christopher Stevens
Message 14 of 15
EddieMoreno
Excellent Chris. Great description and method. I’ll be sleeping a little better knowing I have some good options. Thanks!
Message 15 of 15
BrianHailey
I agree with @ChrisRS, best to make a copy of the drawing at that point as you'll need to copy both the surface, as well as the data.
GEI Consultants
My Civil 3D Blog
Rail Community
