OK, this may seem backwards, but I wanted to know if there is a way to copy Point Groups to previous vesions of Civil 3D. Unfortunately we have to use Civil 3D 2010-2014(because various clients are not up to 2014 yet). I do a lot of topographic surveys and I set up a bunch of point groups for various features (Top Face of Curb, OG Shots, Back of walk, etc.) and unfortunately I set these all up in 2014. My template is set up in 2010 and I really do not want to set up 20-30 different point groups all over again. I set the different groups up to have different colors in order to easily identify the points while buildiing the topo.
I have tried saving the drawing as a 2010 version, but no point groups show up so I can't just drag and drop them in the prospector and the Import styles option does not bring over Point Groups.
Any suggestions or am I just SOL and I have to set these up individually again?
Chris
Solved by tcorey. Go to Solution.
You can use LandXMLOut command.
Yes, the Civil 3d 2010 Template is used for all versions of our Civil 3D. So I want to incorporate the Point Groups into that template so they will be available in all versions.
I will check out Jeff's method a little later today.
Chris
