Civil 3D Forum
Copy styles to another drawing
3 REPLIES 3
7814 Views, 3 Replies
Is there a way to copy a style (i.e. labeling style) from one drawing to another?
3 REPLIES 3
Alfred.NESWADBA
depends on your Civil3D-version!
With 2012 you have the possibility to import styles from any drawings (plus clean styles), command _IMPORTSTYLESANDSETTINGS (_PURGESTYLES for cleaning).
With 2011 or older you can drag&drop single styles, so open the source-drawing and the destination-drawing. Place them side-by-side in the AutoCAD-applicationwindow (e.g. command _SYSWINDOWS ==> _VERT), than active the source-drawing, now you can drag a style from the Civil-prospector/styles to the window of the destination drawing.
HTH, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
Thank you,
That worked perfect.
One more questions.  How do I set a particular style as current?
Thanks.
Alfred.NESWADBA
Civil3D-styles work different compared to AutoCAD dimensionstyle or textstyle. In most cases you can set the style (and also other presettings) by finding the command that's used to create a Civil3D-object.
So for example if you want to set the default style for creation of a surface:
  • goto Civil3D-prospector
  • change to "settings"
  • A) right-click on "surface" ==> "object-settings" (hope that is correct translated from my german version) .... here is the first point to define the default-style for surfaces
  • B) alternative is to open "surface" ==> "commands" and right click on "CreateSurface" or "CreateSurfaceFromTIN" or "CreateSurfaceXXXX" .... here you can override the default settings (and default surface-style) dependig on how you create a surface (what type of surface will be created)
HTH, - alfred -
Alfred NESWADBA
Rail Community
