Is there a way to copy a style (i.e. labeling style) from one drawing to another?
Solved by Alfred.NESWADBA. Go to Solution.
depends on your Civil3D-version!
With 2012 you have the possibility to import styles from any drawings (plus clean styles), command _IMPORTSTYLESANDSETTINGS (_PURGESTYLES for cleaning).
With 2011 or older you can drag&drop single styles, so open the source-drawing and the destination-drawing. Place them side-by-side in the AutoCAD-applicationwindow (e.g. command _SYSWINDOWS ==> _VERT), than active the source-drawing, now you can drag a style from the Civil-prospector/styles to the window of the destination drawing.
HTH, - alfred -
Thank you,
That worked perfect.
One more questions. How do I set a particular style as current?
Thanks.
Civil3D-styles work different compared to AutoCAD dimensionstyle or textstyle. In most cases you can set the style (and also other presettings) by finding the command that's used to create a Civil3D-object.
So for example if you want to set the default style for creation of a surface:
HTH, - alfred -
