Hey all,
Me and some fellows at work have been noticing a significant increase in the time it takes to copy with base point and paste into a different drawing file. Maybe it is just the 2012 version of the software but I am hoping someone out there will be able to let us know what has changed or how to minimize the time this takes. I don't see any reason it should take up to a minute to copy a few polylines from one drawing to the next.
Thanks for your time!
Jeremy
Can also happen if there are any DGN linetypes.
WBLOCK the current drawing and check the new file.
Consider reading the below post also.
jhwiz wrote:it should take up to a minute to copy a few polylines from one drawing to the next
Does the issue occur on every drawing, even between two blank, empty ones..?
If you are looking for a compiled version of the above code , you can download from here
DGN Purge (Not updated with the revised code from Kean's website)
Please note that the above dll is as per the first post of Kean's webpage.So run it on a copy of your drawing to see the result.
