Civil 3D Forum
Copy/Paste Latency
5 REPLIES 5
jeremy.hellman
452 Views, 5 Replies
Copy/Paste Latency
Hey all,
Me and some fellows at work have been noticing a significant increase in the time it takes to copy with base point and paste into a different drawing file. Maybe it is just the 2012 version of the software but I am hoping someone out there will be able to let us know what has changed or how to minimize the time this takes. I don't see any reason it should take up to a minute to copy a few polylines from one drawing to the next.
Thanks for your time!
Jeremy
5 REPLIES 5
Jay_B
in reply to: jeremy.hellman
We use 2012 and havent had any issues with it AFAIK.
What have you tried?
Try SCALELISTEDIT>Reset
-purge>R (for registry applications, note the dash.
Purge
Audit
Cleaning out AutoCad temporary folder.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Can also happen if there are any DGN linetypes.
WBLOCK the current drawing and check the new file.
Consider reading the below post also.
DGN Purge Tool
Does the issue occur on every drawing, even between two blank, empty ones..?
No, If I start up a brand new empty drawing, create a few lines and try to copy paste into another brand new drawing it is fine.
Any design drawing we have though seems to be plagued in this way. We may have narrowed down the problem to a common basefile we use for powerlines, it is probably more common than that one basefile though. I will try to get someone on our team to compile the DGN Purge Tool above and report back.
If you are looking for a compiled version of the above code , you can download from here
DGN Purge (Not updated with the revised code from Kean's website)
Please note that the above dll is as per the first post of Kean's webpage.So run it on a copy of your drawing to see the result.
Rail Community
