Civil 3D Forum
Copy Multiline Attribute Information - Revision numbering
1 REPLY 1
burt46
228 Views, 1 Reply
I have a number of drawings that i need to change the revision numbers, insert the date, the reviewer, ect.... I have been doing this manually but it takes heaps of time. Is there an easier way to copy and paste multiline attributes from one block to the same block used in other drawings (each drawings has the same block and atrribute titles). One problem is that i cant simply copy the entire block as the drawing number, reviewers, titles ect are different in each drawing.
I'm sure there is an easy answer or lisp for this. Any help would be appreciated.
Many thanks
I'm using Civil3D 2012
1 REPLY 1
Lisa_Pohlmeyer
in reply to: burt46
Perhaps you could create a script file and then use ScriptPro to process multiple drawings.
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
Rail Community
