Civil 3D Forum
Coordinate grid on layout in Civil 3D 2010 or 2011
11 REPLIES 11
Message 1 of 12
aldan8
7309 Views, 11 Replies
hi, how create coordinate grid on layout in Civil 3D 2010-2011, such as this
11 REPLIES 11
Message 2 of 12
Civil3DReminders
in reply to: aldan8
Check out the tools in the UKIE Country Kit.
Christopher
http://blog.civil3dreminders.com/
Message 3 of 12
aldan8
in reply to: Civil3DReminders
thx, but I don't need  concrete style , I just want know how do it step by step in Civil 3D 2010 or 2011 with any style
Message 4 of 12
neilyj666
in reply to: aldan8
There is a tool in MAP that will do this (not sure about 2010 but presume it will) but not in front of it now so don't know what is is...
Not sure what you mean by "any style" - the grid will appear as the programmer intended, if you want something different you'll have to wite your own routine or add the grid manually in your preferred style.
As mentioned there is a tool in the UKIE country kit (and there are other lisps e.g.CVP.lsp available) that will put a grid in a viewport and they work well
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 5 of 12
aldan8
in reply to: neilyj666
Can you tell me how to use it in the UKIE country kit.
Message 6 of 12
Civil3DReminders
in reply to: aldan8
Check out this video: http://www.youtube.com/watch?v=ovq0ZWovnSc For other help, check out the PDF that has the instructions for the Kit.
Christopher
Message 7 of 12
aldan8
thanks. but  the tool in the UKIE country kit  this hasn't what I was looking for
Message 8 of 12
david.zavislan
in reply to: aldan8
In Civil 3D 2011/Map 3D 2011 use the MAPLAYOUTREFERENCESYSTEM command to add a grid to a layout viewport.  It will create a "Military Grid Reference System".  I think that 2012 has more options that allow the grid to be customized.
David Zavislan, P.E. | Wood Rodgers, Inc.
Message 9 of 12
aldan8
in reply to: david.zavislan
thx , OK, I'll try this
Message 10 of 12
O.Maille
in reply to: aldan8
Ok the 2013 release has incorporated this item but is there any way to customise the way it looks? Ideally I'd like a mix of the two; tics and crosses like the UK IE and number outside the viewport. I'm sure there must be some setting.xml to chage the appearance, obviously hadn't enough time thie year to encorporate customisation into the release.
Message 11 of 12
Thank you for this tip.  There are multiple choices in 2012 version.  This includes Current Map Coordinates which allows US Feet if that is the units used.  We have been searching off and on for an easier solution than creating alignments or blocks. Smiley Happy
Message 12 of 12
Rail Community
