I have a created a TIN surface with a DEM file. Drawing coordinates are State Plane NAD 83 feet. DEM file coordinates are UTM NAD27 meters. Surface is shifted approx. 835 miles east.
Best practice for this is to create a surface and Add a DEM file under definition. When in the dialog box, you must match the CS code to what the DEM file is, NAD27 meters. When you do this, it will transform for you.
If he does the operation that I posted, it will work for him.
Yes sir. Not many know that there is that option. Most think the only option is the way you suggested or creating a surface from a DEM. Creating a surface from a DEM, has never been a good choice
