AutoCAD Civil 3D General
Valued Contributor
rcallison
Message 1 of 3 (557 Views)
Converting Metric to Imperial
557 Views, 2 Replies
09-21-2012 07:51 AM
How do I convert a dwg file from Metric to Imperial?
sboon
Message 2 of 3 (553 Views)
Re: Converting Metric to Imperial
09-21-2012 08:01 AM in reply to: rcallison
There is no direct conversion tool or method.  Create a new drawing from an Imperial template and then insert and explode your source file.  You'll probably have to go through it and update or replace all of the metric styles with their Imperial equivalents.
Distinguished Mentor
rl_jackson
Message 3 of 3 (545 Views)
09-21-2012 08:29 AM in reply to: sboon
Under the assumption that your drawing is say metric state plane coords, you can use Map to pull the data into your impearial drawing see to US survey foot in the same coord system. otherwise just insert / scale the drawing to convert from metric to imperial.
C3D12-13
Win7x64 6gb
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
