Valued Contributor
jamesbarnett
Message 1 of 4 (1,966 Views)
Convert surface boundary to polyline
1966 Views, 3 Replies
02-01-2013 08:24 AM
I need to convert my surface boundary to a polyline so I can use it to clip another surface. Is there a simpler way than tracing it with the polyline command?
AutoCAD Civil 3D 2014 SP 1
Windows 7 (64)
Valued Mentor
Valued Mentor
sjg
Message 2 of 4 (1,961 Views)
Re: Convert surface boundary to polyline
02-01-2013 08:57 AM in reply to: jamesbarnett
Yeah. Turn your border on within your surface style, select surface and within contextual ribbon there is a extract objects icon, then a dialogue will pop up asking what you would like to extract. Uncheck everything except for border, hit ok. Border will be extracted as a 3dpolyline. Turn off border within surface style, CONVERT3DPOLYS, command to convert into polyline.
Steve Goessling
Land Consultants
Civil3D 2013
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
*Pro
dgordon
Message 3 of 4 (1,935 Views)
02-01-2013 11:59 AM in reply to: sjg
also after getting a polyline from this method remember to use drawing cleanup with the simplify linear objects and set it to 0.5 tolerance to reduce the number of vertices drastically.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
Valued Contributor
jamesbarnett
Message 4 of 4 (1,921 Views)
02-01-2013 03:13 PM in reply to: jamesbarnett
Thanks guys!
Windows 7 (64)
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
