jbear0000
Message 1 of 6 (3,565 Views)
Convert multiple polylines to arcs
3565 Views, 5 Replies
05-22-2012 10:29 AM
I have many segmented polylines that I need to turn into arcs. See the attached image for the method I use to create an arc from a single polyline. I need to do this to thousands of polylines. Does anyone know of a lisp that could do this? Or maybe some other method that can do many polylines at once?
tcorey
Message 2 of 6 (3,555 Views)
Re: Convert multiple polylines to arcs
05-22-2012 11:24 AM in reply to: jbear0000
Unfortunately, the aecccreatearcbybestfit command is not exposed to VisualLISP, so no luck there.
If you don't need the Best Fit functionality of that command, you can use Pedit, Multiple, Fit curve. That would do them all in one fell swoop. It won't be a single arc through the entire pline, but it will have tangent curve segments. Depending on your need for speed vs. your need to obtain a single best-fit curve, this might work as a solution. It would be fast, that's for sure.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
jbear0000
Message 3 of 6 (3,544 Views)
05-22-2012 01:35 PM in reply to: tcorey
I figured out a way to do it. First I use Pedit to fit a curve like tcorey suggested. Then I use mapclean and select Simplify Objects, set the tolerance to 1 and check the Create Arcs check box. This creates 2d polylines which can then be exploded to get arcs.
controlsgirl
Message 4 of 6 (2,881 Views)
05-02-2013 10:35 AM in reply to: jbear0000
jbear, what is mapclean?
troma
Message 5 of 6 (2,878 Views)
05-02-2013 10:37 AM in reply to: controlsgirl
Type MAPCLEAN at the commandline.
Credit where credit is due! Give kudos or accept as solution whenever you can.
jbear0000
Message 6 of 6 (2,878 Views)
Mapclean is a command, type it and mess around with it.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
