I have a .crd file which i need to convert to ASC1II file to then import into civil 3d to build a ground model. I have used the survey link as suggested in a previous post
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Trimble-crd-files/td-p/3071162
However when i click convert i get an error saying points not found, please see attached.
Does anyone have any other suggestions as to how i can go about importing the .crd file?
Rick Jackson
Survey CAD Technician VI
Rick Jackson
Carlson's internal binary point db is .CRD also.
They have a standalone tool to convert that to PNEZD.
The MX version is an ASCII Text file albeit in a weird format....
C&G also used the CRD file extension and it's binary format differs from Carlson. Post your file and we can tell you more and likely convert it for you.
Take the simple path, go to; http://www.stringersurvey.com/prod01.htm and down load Stringer Connect.
The program is free and with about three or four clicks of the mouse you will have a FBK file. You can use the fbk to generate your line work.
