Hello:
AutoCAD Civil 3D 2012
I have been drawing in a Civil 2012 .dwg and need to import some AECC points. I know I can convert ALL of them over but there are thousands. I just need to convert about 20 points over. This would leave out the points I do not need and since some of the Civil 3D point numbers and AECC points are duplicate point numbers, I wouldn't have to renumber.
Any ideas??
Thanks!
Dan
I would copy the AECC points you need and paste them into an empty drawing for the conversion. You can then export them to a .csv file and import the .cwv into your original drawing. This way you can either renumber as needed on import.
