Civil 3D Forum
Convert Autocad surface to Civil 3D surface
5 REPLIES 5
1951 Views, 5 Replies
Does anybody know if it is possible to convert an autocad surface to civil 3d surface?
5 REPLIES 5
autoMick
I don't believe a direct conversion is possible, however see http://forums.autodesk.com/t5/AutoCAD-Civil-3D/River-bottom-surface-from-3dpolyline-sections/m-p/360... in which I outlined one way in which 3D geometry could be utilised for a c3d surface.
Cheers
- Mick
Civil3d user in Australia since 2012.
Thanks Mick! Will explore it.
Best,
Fidel
antoniovinci
The easiest way is to explode the Acad surface, getting a bunch of 3Dfaces.
Finally you add those 3Dfaces to a new C3D surface definition.
troma
in reply to: antoniovinci
When you add 3D Faces, make sure to check off "Maintain edges"
Unless you really don't want to.
Mark Green
Working on Civil 3D in Canada
Thanks Troma and all of you guys. That is exactly what I was looking for.
Rail Community
