AutoCAD Civil 3D General
Distinguished Contributor
drafter1411
Message 1 of 2 (135 Views)
Accepted Solution
Contours
135 Views, 1 Replies
01-16-2014 01:40 PM
I can I set contour label precession? I want this 10 not 10.000.
Thanks for any help
Active Member
Hammerling
Message 2 of 2 (129 Views)
Re: Contours
01-16-2014 02:13 PM in reply to: drafter1411
Yes.
This is controlled in the contour label style.
One way to go to the
  • annotate tab,
  • select add labels.
  • in the dialogue box select feature to SURFACE, and
  • label type to CONTOUR any will work
  • click  on the edit icon to the right of the name,
  • select layout tab
  • pick the  right column, 1st row in text,
  • then pick the .... To open a new dialogue box.
  • In the right window, pick in the text,
  • on the left side make your adjustments.
  • !!!!!!!!!!!!!   IMPORTANT    !!!!!!!!!!!!!
    when done click the arrow pointing right to apply these setting to the style.
  • OK out of all the dialogue boxes.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
