Thanks Peter, I thought just picking the Plus sign next to "Top" in the Add
Data box of the Surfaces Tab of Corridor Properties would do it, but what I
had to do is change the data type to Feature Lines, and then pick the Codes
that I wanted to have feature lines assigned to. That is after I created
codes for the subassembly polyline. Thanks for getting me back in the right
corridor. (so to speak)
I have a new problem, that I am going to ask in a new thread if you happen
to have time to look at it.
Thanks, Tim
; "Inc" wrote in message
news:5054862@discussion.autodesk.com...
Tim,
Did you apply a "Top" link code to the polyline subassembly? If not, then
the links formed by the polyline won't get added to the surface (resulting
in exactly what you see).
You can also add point codes at the sides of the ditch if you want ditch
lines in plan.
Cheers,
Peter Funk
API Product Manager
Autodesk, Inc.
