AutoCAD Civil 3D General
nathan.hendrickson
Message 1 of 4 (1,717 Views)
Contours not plotting in paper space Civil 3D 2012
1717 Views, 3 Replies
10-28-2011 11:12 AM
I have been having this issue for a few weeks, where my contour lines will not plot in paper space, but the labels do.  If I plot from model space everything shows up.  All layers have been checked and nothing is frozen or turned off in the viewport.
Valued Mentor
gjrcmb
Message 2 of 4 (1,704 Views)
Re: Contours not plotting in paper space Civil 3D 2012
10-28-2011 12:33 PM in reply to: nathan.hendrickson
So you can see the contours in Paperspace, but they do not show up plot preview?
If you are not seeing the contours in Paperspace, double click within the viewport to open it to Model Space and then make sure that "Viewport Freeze" is not frozen for the layer.  Or if you are seeing the contours, make sure that "VP Color" is set to the same thing as the "Color" for layer in case it is related to the color and your Plot Style file.
New Member
Message 3 of 4 (1,647 Views)
11-08-2011 03:55 PM in reply to: nathan.hendrickson
I had the same problem in Civil3D 2012 make sure you have the Level of Detail set to Off. This can be done from the View Tab - Level of Detail. Or just type in Levelofdetail.
Cheers
Neil
New Member
Message 4 of 4 (1,189 Views)
10-01-2012 10:14 AM in reply to: mcintyr
You rock! I have been having this issue and searching for awhile for an answer. This worked perfectly!!
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
