rvandever21
Message 1 of 5 (628 Views)
Contour lines display
628 Views, 4 Replies
09-19-2012 12:38 PM
I am having problems viewing my contour lines after I create a surface. I create the surface using points.  The contour lines will show up when I create the surface. After I close the program or the drawing, I am not able to see the contour lines again. The contour lines are on in the surface style.  How can I see the contour lines without creating the surface again?
neilyj
Message 2 of 5 (623 Views)
Re: Contour lines display
09-19-2012 01:04 PM in reply to: rvandever21
Do you have Level of detail switched on??
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
rvandever21
Message 3 of 5 (613 Views)
09-19-2012 01:24 PM in reply to: neilyj
Where can I find the level of detail?
neilyj
Message 4 of 5 (604 Views)
09-19-2012 01:33 PM in reply to: rvandever21
see screenshot - can you post the dwg if this doesn't solve the problem??
neilyj
rvandever21
Message 5 of 5 (520 Views)
11-13-2012 01:23 PM in reply to: neilyj
That worked. Thank you.
