Civil 3D Forum
Contour labels - exporting to AutoCAD
6 REPLIES 6
1505 Views, 6 Replies
I need to export a contour plan of a surface model to vanilla AutoCAD.
However, the contour labels do not follow the contour lines when I use "Extract Objects from Surface".
Any ideas, anyone?
6 REPLIES 6
I think I can help. It's a several step process really.
First, you will want to select only the contour labels and explode them twice. The first explode will turn your labels into blocks. The second explode will turn them into text.
Second, cut and paste them into a new drawing. Then go back to your original drawing and do a few undos to restore your labels to their original state.
Now you have your labels that you can combine with your contours in their own drawing, and your C3D drawing is still intact.
This is how I have always done it, but just like everything else in autocad, I am sure there are at least 10 other ways.
rick
Matt.Anderson
Are you exported down a version? or does the "end" vanilla user need to manipulate the contours?
If either answer is no, why export? Be sure the end user has the object enabler for Civil 3d, and be sure proxygraphics is on before you save the file for them.
Matthew Anderson, PE
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
The end user does not have Civil3D, only normal vanilla AutoCAD.
Matt.Anderson
Same release as Civil 3d ?
vanilla AutoCAD should open the Civil 3d drawing up fine. Will he be able to manipulate Civil 3d data? No. But the picture is there and the labels will react appropriately.
Product Manager
Autodesk (Innovyze)
kcobabe
Actually you need to get the object enablers if you end up with boxes.
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
Matt.Anderson
boxes only if proxygraphics not enabled on C3d end. Message was edited by: MAnderson
Product Manager
Autodesk (Innovyze)
Rail Community
