AutoCAD Civil 3D General Discussion
Active Contributor
eyescast
Message 1 of 2 (121 Views)
Contour Values disappears on render material
121 Views, 1 Replies
02-04-2013 10:09 AM
Hi again,
The contour values when place on the the render material of rock image it disappears so I had to place it on the
side.
Is this a layer issue? or  how the image is use a render material?
thanks again.
eyescast
Valued Mentor
Valued Mentor
sjg
Message 2 of 2 (109 Views)
Re: Contour Values disappears on render material
02-04-2013 12:06 PM in reply to: eyescast
Are you using a mask to clip the image, if so check your display order.
Steve Goessling
Land Consultants
Civil3D 2013
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
