SSAuburn
Message 1 of 6 (1,049 Views)
Contour Lines not displaying correctly.
1049 Views, 5 Replies
10-16-2012 06:53 AM
What is the easiest way to correct contour lines when they don't display correct?   Adding points, deleting points, switching edges...
See everything circled in orange on attached pdf.
Distinguished Mentor
castled071049
Message 2 of 6 (1,047 Views)
Re: Contour Lines not displaying correctly.
10-16-2012 07:00 AM in reply to: SSAuburn
Assuming that is a corridor-related berm you've created, it looks like you have some targeting issues, maybe? Hard to tell.
SSAuburn
Message 3 of 6 (1,044 Views)
10-16-2012 07:02 AM in reply to: castled071049
What do you mean by target issues?
castled071049
Message 4 of 6 (1,040 Views)
10-16-2012 07:06 AM in reply to: SSAuburn
For example, in the area marked "Two C Pipes", the contour issues look like the something is amiss, perhaps, with the berm grading back to existing grade? Lots of things can be causing your problem, I'm just guessing at one that might be a cause.
jmayo
Message 5 of 6 (1,026 Views)
10-16-2012 07:46 AM in reply to: SSAuburn
If this is an exisitng topo or a feature line or a grading design I would be fixing the breaklines and/or removing the bum shots creating these issues. What I see in your file is what I see in our files when the surveyor used points in the surface for objects sticking out of the gound (or underground) like top of hydrants, top of headwalls, (pipe inverts) etc. or when breaklines are required but are not modeled.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
jmayo
Message 6 of 6 (1,024 Views)
10-16-2012 07:48 AM in reply to: jmayo
If you added contours to the surface definition I would make sure that you have the Minimize Flat Areas option checked. This should fix the errant contours going over the flat areas.
John Mayo, PE
IDSP 2014
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
