Civil 3D Forum
Contour Label Directions
8 REPLIES 8
Message 1 of 9
jamesbarnett
3550 Views, 8 Replies
Is there a way to change the direction of a Label? I want all my text facing the same direction and some of my Labels for contours are turned the wrong direction.
AutoCAD Civil 3D 2022
8 REPLIES 8
Message 2 of 9
g_k50
in reply to: jamesbarnett
Click on the contour label and move it over a little bit, it might flip upright.
Message 3 of 9
jamesbarnett
in reply to: g_k50
I tried that. I have to move it to far.
Message 4 of 9
_Hathaway
I have never had to do this but if you go into the contour label style editor you can manipulate the settings to achieve the desired results. It may take some trial and error.
Message 5 of 9
awood
You can try turning Plan Readable to False in the Label Style.
HTH
AWood
Message 6 of 9
g_k50
You could rotate your cube until the label flips.
Message 7 of 9
In your text style under the General tab, change the Readability Bias to 90.
Todd Rogers
Message 8 of 9
jamesbarnett
in reply to: awood
Turning the Plan Readability off fixed my issue.
Thanks everyone.
Message 9 of 9
r0d0nuff
Try changing the direction of your polyline using PEDIT.
Rail Community
