Civil 3D Forum
Connect pipe offset from center of structure?
6 REPLIES 6
1093 Views, 6 Replies
Is there a way in the current release to connect a pipe to a structure
other than at the center? I've got a 10' Type-R inlet that needs a pipe
to exit one of the sides.
Thanks.
Darron Agawa
C3D 2006 SP2, HF2
LDT 2006 SP1
6 REPLIES 6
nzeeben
James once told me if you drag the pipe off center and not outside the structure it will stay connected. I tried it out, and it even worked like he said. It is the best we got right now. HTH
That works great. I don't know why I didn't try that. Thanks.
Darron Agawa
C3D 2006 SP2, HF2
LDT 2006 SP1
nzeeben
You probably didnt for the same reason I didn't. I couldnt figure out why that would work. I just assumed that since they snapped to middle they were stuck there.
It's pure serendipity on my part...
James Wedding, P.E.
Engineered Efficiency, Inc.
Civil 3D 2006 SP2
XP Tablet, SP2, 2GHz, 1.5G
www.eng-eff.com
www.civil3d.com
Somewhat along this same topic, do you like the fact that dragging the
grip of a pipe or structure determines not only it's horizontal
position, but also it's vertical? I wanted to line a pipe up with my
base linework (all at z=0 of course) and the pipe or structure is pushed
down to zero elevation in my profile. I can't see how this would be useful.
Darron Agawa
C3D 2006 SP2, HF2
LDT 2006 SP1
MikeEvansUK
in reply to: nzeeben
Nick, don't know if your still on the team but when a pipe is dragged it does not always stay connected. This seems to be hit and miss and with no warning.
I just got caught out again with this on a live project with an offset pipe. Can we please have some feature to warn us of this when it diconnects inadvertantly from the structure and as quick as possible please.
We cant have incorrect information slipping through the net.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Rail Community
