Civil 3D Forum
Confirmed Defect - Section Editor Display Layer Control
17 REPLIES 17
Message 1 of 18
fcernst
1310 Views, 17 Replies
Description:
The Section Editor is not turning off layers in Section View. It is showing all sorts of skewed entities .
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
17 REPLIES 17
Message 2 of 18
ToddRogers-WPM
in reply to: fcernst
Love it!!  Thanks Matt.
Todd Rogers
Message 3 of 18
Lisa_Pohlmeyer
Well, now THAT will keep us from deploying for sure!  We live on sections!  Dang, darn, shoot, !@#$%^&^&&***
It may only be the editor, but it's enough to really confuse folks.  I hadn't quite gotten to that worflow yet in testing for deployment.  Thanks Fred.
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
Message 4 of 18
bruce.jordan
Yep - another good reason why not to implement into production until at least the first SP.
Message 5 of 18
neilyj666
Gotta love the speed that Autodesk get around to fixing defects.....now if this was Autodesk 360 it would be fixed embarassingky quickly no doubt.....
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 6 of 18
sboon
in reply to: neilyj666
If they're fixing other things in the Section View/Editor then perhaps they can deal with the grid linetype issue also.  Here's what happens if I forget to check the current linetype before starting the View Editor.
Not a huge problem, but if you're working on that part of the code anyways...
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Message 7 of 18
fcernst
in reply to: Lisa_Pohlmeyer
Yes, here too as an engineer. Typically have three viewports(Section, Plan, Profile) with Station Tracker on (really like this feature).
I don't know how this stuff gets out the door in this condition...We need strong Civil 3D product leadership desparately.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 8 of 18
MikeEvansUK
Its a pity the minimise / maximise viewport feature breaks the section editor command and has done since it was incorporated into the package!!! I found it in the first beta version, never been fixed.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Message 9 of 18
fcernst
Installed Hot Fix 1 and you can see the results below. How can this continue to go unaddressed?
This is totally unacepptable!  We need Section Editor functionality ASAP for our engineering work.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 10 of 18
JeffPaulsen
Which hot fix did you install? I just checked the Updates & Service Packs page and did not see one named Hot Fix 1.
Jeff Paulsen
Civil 3D 2020.4 | Win 10 Pro N 64-bit
Xeon W-2223 @ 3.60GHz, 32GB Ram | NVidia Quadro P2200
Message 11 of 18
mathewkol
It has not made that page yet. The Hotfix is available from withing C3D.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 12 of 18
brawil
Hot fix did not fix this.
Message 13 of 18
neilyj666
in reply to: brawil
Did you honestly expect it to be fixed so soon...this is Autodesk we are talking about and the defect isn't anything to do with a Cloud product...?
Message 14 of 18
RDunkley
We are still waiting for this, and have not yet been able to deploy 2014 as a result.
This is totally unacceptable. Has anyone heard any news on when we can expect this?
Not sure why we are paying for a product that we can't even use...
Currently using Civil 3D 2022
Message 15 of 18
sboon
in reply to: RDunkley
I've been looking at this for a while now, and I'm pretty much convinced that the problem isn't actually related to layers.  The section viewer is supposed to be using the ACad clipping planes function to display a slice of the model at the corridor section but in 2014 the clipping planes are never turned on.
If you open the section viewer then start the DVIEW command you can manually turn on the front and back clips to make the section display properly.  Of course the problem is that as soon as you jump to another station the clips turn off again and you have to reset them.
This seems like it should be a simple enough issue for Autodesk to fix.  If they aren't willing or able to do so then perhaps it would be possible for someone to write a simple program to turn on the clipping planes from a keyboard shortcut or something like that.
Steve
Steve
Message 16 of 18
RDunkley
in reply to: sboon
Thanks Steve,
You are right, it seems so simple. Although I think you meant to say DDView.
Hopefully Autodesk can sort this out ASAP.
Regards.
Ross.
Message 17 of 18
neilyj666
.....ASAP in the world of Autodesk usually translates as next annual release cycle (assuming it'll get fixed at all...!!!)
Message 18 of 18
RDunkley
Good news... Civil 3D 2014 Service Pack 1 is out and has fixed the Section Editor display issue.
Rail Community
