Civil 3D Forum
Concrete pattern in Parcel Hatch
10 REPLIES 10
Message 1 of 11
Joe-Bouza
3594 Views, 10 Replies
I'd like to hatch a parcel with the concrete pattern but it shows broken. I know I could relocate the origin for a polygon hatch but is there a fix for using in a parcel?
Your Name
Your Name
10 REPLIES 10
Message 2 of 11
Pointdump
in reply to: Joe-Bouza
Hi Joe,
Something like this?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 3 of 11
Joe-Bouza
in reply to: Pointdump
Hi Dave
Thanks for the input.
I can get the patter in the style, but it displays as broken lines not aggregate 😞
Your Name
Your Name
Message 4 of 11
Pointdump
Joe,
Can you post a pic? I'd like to see that.
Dave
Dave Stoll
Las Vegas, Nevada
Message 5 of 11
Joe-Bouza
I'll try to get that tomorrow. I was in the weeds today
Your Name
Your Name
Message 6 of 11
MikeEvansUK
This is the same problems as we had with autocad hatches a few releases back due to the hatch being so far from 0,0,0. The only fix was to relocate the hatch origin point or to temporarily relocate a ucs to be closer when the hatch was created.
Have you tried relocating to a UCS closer to the parcel then regenerating the view? this will do what you're after.
Not ideal I know..
M
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Message 7 of 11
hugha
in reply to: MikeEvansUK
Look in the Hatch Dialog's "Hatch Origin" box for a button to pick a new hatch origin.
This refers to it, even has a graphic ...
http://forums.autodesk.com/t5/AutoCAD-2010-2011-2012-DWG/Lock-hatch-origin/td-p/3120258
Message 8 of 11
Joe-Bouza
in reply to: hugha
There is no Hdialog when applying to a parcel - thats the problem, but thanks for the input
Your Name
Your Name
Message 9 of 11
hugha
Sorry, my ignorance of Civil3d is fairly complete.
This looks like a case where a more accurately specified hatch pattern would provide an answer to the loss of precision arising from using a pattern at coordinates well away from the hatch's current origin.
It's been a while since I posted here. I hope the attachment works, otherwise cut and paste the pattern directly from this panel.
*AR-CONC2,Random dot and stone pattern
;        Pattern written by HatchKit v2.7 Hatch Pattern Editor
;        HatchKit v2.7 Hatch Pattern Editor(c) Cadro Pty Ltd 1990-2008.
;        www.cadro.com.au/hatchkit/
71.4514447388,1.4974,1.1645,1.9182358991,6.93976736169,0.6374,-7.0114230388
-34.0000000164,1,1.5,5.16218792505,7.37236840008,0.6,-6.59999999993
21,1,1.5,4.87024966,5.89789472,0.75,-8.25
96.6356447388,0.88937,1.8621,2.87735384866,10.4096510425,0.9561,-10.5171345582
-8.81580001637,0,2,7.74328188758,11.0585526001,0.9,-9.89999999989
46.1842,0,2,7.30537449,8.84684208,1.125,-12.375
100.451444739,0.59772,-0.052293,1.9182358991,6.93976736169,0.6374,-7.0114230388
-5.00000001637,0,0,5.16218792505,7.37236840008,0.6,-6.59999999993
50,0,0,4.87024966,5.89789472,0.75,-8.25
7.75374509883,0,0,0.569612851418,3.28209676876,0,-15.521210552
7.75374509883,5.1727,3.9691,0.569612851418,3.28209676876,0,-15.521210552
7.75374509883,10.488,8.0478,0.569612851418,3.28209676876,0,-15.521210552
9.74000554536,-3.23,0,2.14228105711,12.4803846346,0,-5.91715400847
9.74000554536,-0.83385,-2.1957,2.14228105711,12.4803846346,0,-5.91715400847
9.74000554536,2.9852,-5.6952,2.14228105711,12.4803846346,0,-5.91715400847
68.8819167095,6.4569,-5.5342,9.21397900388,5.06097174029,0,-10.9268936556
68.8819167095,-0.12152,-1.3432,9.21397900388,5.06097174029,0,-10.9268936556
68.8819167095,-2.23,0,9.21397900388,5.06097174029,0,-10.9268936556
56.2970215044,0,0,1.10616853275,9.56652017074,0,-4.74095117039
56.2970215044,3.7873,0.49861,1.10616853275,9.56652017074,0,-4.74095117039
56.2970215044,10.103,1.3301,1.10616853275,9.56652017074,0,-4.74095117039
Hugh
Message 10 of 11
MikeEvansUK
Joe have you tried what I sugested?
"Have you tried relocating to a UCS closer to the parcel then regenerating the view?"
Mike Evans
Message 11 of 11
Joe-Bouza
Thanks Mike that worked. Thankfully match props worked after that - was not looking forward to settint the origin for each parcel
Your Name
Your Name
Rail Community
