Civil 3D Forum
Concrete Block Retaining Wall sub assembly
1 REPLY 1
1554 Views, 1 Reply
I am wondering if anyone has developed a sub assembly that produces a concrete block assembly using 80mm wide by 200mm high by 2000m long shapes with the initinal tie to a new profile and uses a condition where it creates a new block if the height difference between the new profile and the existing surface is is greater than 200mm (the height of a block).
1 REPLY 1
KMercier_C3D
This old post has a concrete block retaining wall. http://forums.autodesk.com/t5/AutoCAD-Civil-3D/SAC-Marked-Points/m-p/3197982#M162176
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
Rail Community
