AutoCAD Civil 3D General
Active Member
ph17il
Message 1 of 6 (517 Views)
Composite profile of a surface
517 Views, 5 Replies
03-25-2011 03:25 PM
I'm using Civil 3D 2011 and working on a planset that requires showing a composite profile of a plan area surface (Basically, I need to show a profile of all the high points on a surface within an area represented along a single alignment).  Is there a way to make this profile short of making multiple profiles and manually connecting the high points to make a single composite profile?
Phil
Neilw
Message 2 of 6 (512 Views)
Re: Composite profile of a surface
03-25-2011 03:56 PM in reply to: ph17il
I would drop COGO points at the high points you want and build a surface from them. Then sample that surface to show it in your profiles.
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
Neilw
Message 3 of 6 (507 Views)
03-25-2011 04:35 PM in reply to: Neilw
Well now I wonder if I misunderstood your task. It s a bit vague. Are you wanting to show all the high points within a set swath width along your alignment? Are you wanting to project all the highpoints of the entire surface onto your profiles? Are you wanting to show a profile of a surface consisting of only the high points (per my first approach)?
WIN 7 64 PRO
RADEON 6450, 1 GB
Valued Contributor
RickGraham
Message 4 of 6 (473 Views)
03-27-2011 05:36 PM in reply to: ph17il
To show the high points, you could use the new Transpotation tools that is an addin. I believe one of those tools has the high pont that I believe you are asking about unless I am misunderstanding your question too.
Rick
BrianHailey
Message 5 of 6 (465 Views)
03-27-2011 09:17 PM in reply to: RickGraham
If anyone is interested in more info on the Transportation Extension, I wrote it up on my blog. You can read about it HERE.
Active Member
ph17il
Message 6 of 6 (427 Views)
03-29-2011 12:35 PM in reply to: ph17il
@ Neil:  Yes, I am wanting to show a profile of a surface sonsisting of only the high points in a certain area - I would like to use an approach that doesn't involve me manually picking the high points to use.
@ Rick:  Thanks for the info - the tool did help, although its still basically the same approach as Neil suggested.
@ Brian: Thanks for the info.
I was able to solve the problem by using the mill and overlay assemblies included in the pavement rehab assembly catalog.  I set a minumum clearance from the existing surface, set the grade to 0 and set the boundary targets to the polyline extents of my area.  The surface that this corridor then created profiled the highest points along the surface in the area I was looking at without me having to manually pick all the high points.
Hope this helps if anyone else runs into this problem.
Thanks for the help and the info!
-Phil
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
