Thank you Matt,
I am using a Civil 3D Companion, so thought I would give it a shot here to see if anyone had some good advice.
The sub-assemblies are all built and defined. I just can not find an option that allows me to link more than 2 sub-assemblies to the road template when I really need to link 4 and sometimes 6 on each side of the template.
Would I be better off creating a single finish grade 2d polyline from one side of the corridor to the other and treating the curbs, walks, beds as 'normal' elements all in a single template? Since I need to add PT codes to allow for the variable widths of each of these elements?
Or am I better off trying to work with the multitude of sub-assemblies? If there is not an option to attach more than 2 sub-assemblies to a template, than the multiple sub-assembly option is not going to work, and that is what I am trying to find out, is there an options to attach more than two sub-assemblies to a template?
I am creating more work for myself by trying to attach multiple subassemblies to road template?
I am not sure which direction would be the best, the desired outcome is that all elements that weave around within the Right of Way will be shown in the cross sections so intelligent design decisions can be made regarding shifting walks left or right to avoid excessive cut or fills, widening planting beds to take up or reduce grading, that type of stuff.
I will also post in the LDD area, see if they have suggestions too.
I have not had to work with so complicated Right of Way elements that need to all show in the cross sections before.
Susan
