AutoCAD Civil 3D General
*Expert Elite*
Message 11 of 33 (678 Views)
Re: Compare Points Perpindicular to Surface
02-12-2012 09:54 AM in reply to: TerryDotson
Here's another third-party option:
http://www.quuxsoft.com/SincpacC3D_Help/SP_DisplayPoints.htm
You should be able to also manage it in C3D without third-party help, using techniques like the one Jeff mentioned above, but it's a lot more time-consuming.
Sinc
andrew.normore
Message 12 of 33 (652 Views)
02-18-2012 11:42 AM in reply to: andrew.normore
Just a little update. After trying and combining the suggestions everybody posted I have found a way to do this that gives the same results as terramodel.
Import as-build points (CSV) into drawing. Elevate points to surface used for design DTM. Export points to a new CSV. Copy elevations from one elevated points CSV to the as-build point CSV, subtract the elevation differences and you have all the deltas for each individual point.
For display, I create a new CSV with the deltas as the description, import into C3D and display the description.
Thanks everybody for the help and suggestions. I would not have figured this out without them.
Windows 7 x 64
Dell Precision M6600 Mobile Workstation
16 GB Ram
i7 @ 2.5 ghz
Civil 3D 2012 SP 1
Civil 3D 2011
Autodesk Inventor 2011
AutoCad Map 3D 2011
*Expert Elite*
Joe-Bouza
Message 13 of 33 (644 Views)
02-18-2012 12:54 PM in reply to: Sinc
I didn't read the rest of the post but those results are the same as updating elevation from a volume surface of EG vs As-Built.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
*Expert Elite*
neilyj
Message 14 of 33 (639 Views)
02-19-2012 02:13 AM in reply to: andrew.normore
The results will be the same but you will need to do some manipulation with points if you want to get the differences tabulated i.e. level differences at specific locations
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2014 (mainly Civil 3D 2014 UKIE SP1 & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
*Expert Elite*
Message 15 of 33 (621 Views)
02-20-2012 02:05 AM in reply to: Joe-Bouza
The confusing thing about that is you need additional points.  Typically, you don't want to change your Survey point elevations.  So you don't want to just select your Survey points and adjust their elevations to match a Volume surface.  And creating copies of those points just adds clutter.
But there are options...  As I said, you may not NEED third-party support like what we and Terry offer, but it can make your life much easier...
Sinc
andrew.normore
Message 16 of 33 (617 Views)
02-20-2012 03:55 AM in reply to: Sinc
In the method I described earlier, the dealings is more with the CSV's than with the points in the drawing. You elevate them once and then delete them as soon as you export. I have tried some third party software and i can not find anything that will generate the delta's and produce a report or points with attributes that represent the deltas.
Windows 7 x 64
16 GB Ram
i7 @ 2.5 ghz
Civil 3D 2012 SP 1
Civil 3D 2011
AutoCad Map 3D 2011
*Expert Elite*
neilyj
Message 17 of 33 (612 Views)
02-20-2012 04:12 AM in reply to: andrew.normore
Copying the required points to a new point group e.g. Deltas and then elevating to the TIN volume surface (might have to create a new surface and paste the TIN volume surface into it for this to work) will allow you to create a C3D table of XYZ of the points of interest where Z will be the delta value.
If you need this in Excel then C3D tables do not lend themselves to doing this unlike vanilla ACAD tables. It is possible by exploding the table and using a lisp to create a vanilla ACAD table and then exporting to Excel.
neilyj
andrew.normore
Message 18 of 33 (610 Views)
02-20-2012 04:15 AM in reply to: Sinc
I do not create a TIN volume surface to complete this process. I just simply elevate the points to the surface I used to create the DTM and export them, then compare them to the points taken in the field. It is a very simple way to do this. Creating a TIN volume surface seems like an unneccassary step in the process.
Windows 7 x 64
16 GB Ram
i7 @ 2.5 ghz
Civil 3D 2012 SP 1
Civil 3D 2011
AutoCad Map 3D 2011
*Expert Elite*
Joe-Bouza
Message 19 of 33 (609 Views)
02-20-2012 04:16 AM in reply to: Sinc
Not for nothing but a desire to not make extra points sounds silly -Not saying Terry's and your app dont look useful, they seem very usefull.
But..... Do you want to save the changes to the file (yes / No)
Choices, life is all about choices
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
andrew.normore
Message 20 of 33 (606 Views)
02-20-2012 04:21 AM in reply to: Sinc
I agree. Life is about choices. What would be ideal is a report than can be created where you select the surface and the points you want to compare and it spits out an xls worksheet with the required info. I have been speaking to some people who say this may be possible in the future but I have not had any positive results.
For me it's about keeping it simple. Importing, exporting, and deleting points is a very simple way to get this task done. However, I would much rather see a solution that is specifically designed to produce these results without creating extra points or surfaces.
Windows 7 x 64
16 GB Ram
i7 @ 2.5 ghz
Civil 3D 2012 SP 1
Civil 3D 2011
AutoCad Map 3D 2011
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
