Civil 3D Forum
Commands not being reconized
5 REPLIES 5
martin888888
177 Views, 5 Replies
I am having commands such as DLLables not being reconized by civil3d.  Would there be a fix for this?
5 REPLIES 5
I am not aware of a command DLLables.... is this possibly a lisp that you need to load?
John Gordon
CAD Manager/Survey Technician
C3D 2018/2020
Microstation
Windows 10
Jay_B
in reply to: martin888888
It's likely because those are commands which only work if you are running the 3rd party add on Sincpac-C3D by Quux Software.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
I posted yesterday that we could not find a solution to labeling a crossing pipe in a profile with an IE (IE at crossing) and Pipe Type.  The response I recieved was a command DLLabels (there was a bunch of DL commands in the doc I was sent).  Might be a lisp routine.
martin888888
in reply to: Jay_B
is that it?  Crazy that you can not create a label style within civil 3d to label the IE of a crossing.
Jeff_M
Yes, I showed you the best way I know of to get what you need. Yes, it's a 3rd part add-on called Siincpac-C3D (which is what the help page you were looking at shows). Yes, C3D could very well come with all sorts of things we each could use, but it doesn't, hence the need for 3rd party software if you want those things.
Jeff_M, also a frequent Swamper
Rail Community
