I am having commands such as DLLables not being reconized by civil3d. Would there be a fix for this?
It's likely because those are commands which only work if you are running the 3rd party add on Sincpac-C3D by Quux Software.
I posted yesterday that we could not find a solution to labeling a crossing pipe in a profile with an IE (IE at crossing) and Pipe Type. The response I recieved was a command DLLabels (there was a bunch of DL commands in the doc I was sent). Might be a lisp routine.
is that it? Crazy that you can not create a label style within civil 3d to label the IE of a crossing.
Yes, I showed you the best way I know of to get what you need. Yes, it's a 3rd part add-on called Siincpac-C3D (which is what the help page you were looking at shows). Yes, C3D could very well come with all sorts of things we each could use, but it doesn't, hence the need for 3rd party software if you want those things.
