When I updated to Civil 3D 2014 the command line no longer gives command line history. I tend to use the history in a number of ways. The only way I have found to retieve the history is to right click, select "copy history" and paste into a text editor (too time consuming). How can I enable my command line to show command line history.
Mark
Solved by Jay_B. Go to Solution.
Enter INPUTHISTORYMODE @ command line, is it set to zero?
If so try entering the initial value of 15.
I run dual monitors so I close my command line and hit the F2 key and keep that window open at all times on my other screen. Looks like you found a solution to the actual problem already but thought I'd just share what I do.
