Civil 3D Forum
Command Line
9 REPLIES 9
Message 1 of 10
sam.cutbirth
531 Views, 9 Replies
Command Line
I will continue to research this myself, but could anyone kindly tell me how to switch Civil 3D back to drawing in absolute coordinates at all times (even during the PLINE command!)?  And what would be a good reason for changing the default coordinate entry at the commandline from absolute to relative, anyhow?  Anyone from Autodesk?
Sam
9 REPLIES 9
Message 2 of 10
sam.cutbirth
in reply to: sam.cutbirth
DSETTINGS / DYNAMIC INPUT TAB / POINT INPUT
For anyone else out there confused as to why their PLINE command, among others, wouldn't work the same as it has for the past couple decades.
Message 3 of 10
albionpjl
What's changed about it?
I installed 2013 a couple of days ago and the comand PLine is working just as it always has since r12 DOS so far as I can see. (Apart from losing the ability to toggle between them with F6 several years ago).
Message 4 of 10
AllenJessup
Not sure what problem you're having or how it relates to the PLine command. But take a look at this image and see if it relates to your problem. As you'll see. The settings should be Cartesian format and Absolute Coordinates.
If your problem is that these values change. Look into adding settings for DYNPIFORMAT and DYNPICOORDS. You can add these to your acaddoc.lsp as:
(SETVAR "DYNPIFORMAT" 1)
(SETVAR "DYNPICOORDS" 1)
Allen
Allen Jessup
CAD Manager - Designer
Message 5 of 10
AllenJessup
This may be helpful. It doesn't apply directly to your problem (I don't think) but I just found it and realized that by setting COORDS to 2. I can get what I want to see.
COORDS
Allen
Allen Jessup
Message 6 of 10
sam.cutbirth
in reply to: albionpjl
Try changing the setting I referenced.  Up until I installed 2012, if I feed (copy and paste from a .txt file) a 1000 point list of coordinates to the command line to draw a pline with 1000 vertices, I get a line with a corner at every coordinate listed in my file.  The coordinates respect the grid.  Now switch the control to "Relative," and Autocad plots the next coordinate with respect to the previous coordinate, instead of with respect to 0,0.
Message 7 of 10
sam.cutbirth
in reply to: AllenJessup
Allen, thanks.  I have the right setting now.  It just suprises me to see that setting default to relative instead of absolute.
I assure you, in the past my out-of-the-box installation defaulted on absolute point entry as far back as I can remember.
Message 8 of 10
AllenJessup
You're welcome. I don't know if it was in 2012 or earlier I noticed it. But since I stuck the variable in the acaddoc.lsp it gets set each time. So I don't see it happen now.
Allen
It cracks me up that the spell check tries to change acaddoc.lsp to codswallop! Smiley Very Happy
Allen Jessup
Message 9 of 10
albionpjl
It defaulted to absolute coords for me, out of the box.
But why copy paste from a txt file? If I have a lot of points to draw from a file, I change the extension to scr, add  _Pline
to the first line, save, and then type script in the Cad command line. Load the scr file and watch the line draw itself while I sip my coffee..
Message 10 of 10
sam.cutbirth
Noted.
Rail Community
