Civil 3D Forum
Command Line Auto-Hide?
17 REPLIES 17
Message 1 of 18
Pointdump
4375 Views, 17 Replies
Can you set the Command Line to Auto-Hide? I know I can set the transparency down to 10%, but Auto-Hide would be better.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
17 REPLIES 17
Message 2 of 18
Jay_B
in reply to: Pointdump
In 2013 and 2014, if you set the Command Line to floating or undocked, right click on the left grey bar of Command window>Autohide.
Not sure if this works for earlier releases.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 3 of 18
Jay_B
Another way of doing this is to close command line by clicking the X on upper Rt. Corner and using Ctrl 9 to open it each time.
C3D 2018.1
C3D 2016 SP4
Message 4 of 18
Pointdump
in reply to: Jay_B
Jay,
Thanks. I've been using Ctrl + 9, but I miss things when the command line is off. I would like only the text lines to auto-hide, and it used to do that after a delay of several seconds. Nothing happens when I right-click the grey bar. I can only click the "X" or the Wrench.
Dave
Dave Stoll
Las Vegas, Nevada
Message 5 of 18
Jay_B
Dave, sorry about that, I'm seeing the same here in 2014 maybe it can't be done.
C3D 2018.1
C3D 2016 SP4
Message 6 of 18
Pointdump
in reply to: Jay_B
Thanks, Jay. I'm glad to know it's not just me.
Dave
Dave Stoll
Las Vegas, Nevada
Message 7 of 18
neilyj666
in reply to: Jay_B
Try changing lines of prompt history to 1?
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 8 of 18
Pointdump
in reply to: neilyj666
Neilyj,
Tried that. It doesn't seem to change anything. The number of text lines remains the same.
Dave
Dave Stoll
Las Vegas, Nevada
Message 9 of 18
neilyj666
Did you try setting to 0?
Message 10 of 18
Pointdump
Neilyj,
Yep. I tried numbers from zero to 20, and I'll be darned if I can figure out what that setting changes.
Dave
Dave Stoll
Las Vegas, Nevada
Message 11 of 18
neilyj666
My last shot - try increasing the width of the command promt window so the text fits on one line (in the screenshot the promptlines is 0)
Message 12 of 18
neilyj666
and then back to 3
Message 13 of 18
Pointdump
Neilyj,
Well, thanks for trying, but I went back and forth between zero and 3, and nothing changed.
I'm going to dig up 2012 and see if the auto-hide worked on that version.
Dave
Dave Stoll
Las Vegas, Nevada
Message 14 of 18
Pointdump
2012 lets you Auto-Hide the Command Line.
Dave
Dave Stoll
Las Vegas, Nevada
Message 15 of 18
jesse.design
Hi Dave,
You can't Auto-hide in 2014 but you can change the transparency to clear except when you roll-over it then it turns solid.
Message 16 of 18
Pointdump
in reply to: jesse.design
JD,
Thank you. I'm using 2016, and I do as you say, keeping it almost completely transparent unless I roll over it with my cursor.
Dave
Dave Stoll
Las Vegas, Nevada
Message 17 of 18
aeshleman
I know this is an old thread but I ended up clicking on the dots just above the X on the command line and dragging it down until just the command line was showing, then the clipromptlines variable worked.
Message 18 of 18
 To only show command history translucently and temporarily and according to your input history lines setting, you need to reduce the vertical size of the command line to its minimum (so only the command input line, the one in white, is showing).
I would still like the autohide feature on new releases but, oh well.
Rail Community
