Ok, so I have an oddly shapped "cut" area with various elevations that I want to create as a surface so that I can compare the volume with existing survey data. I've been able to get the basic "cut" template in 2 seperate surfaces, but now I want to combine them into 1 surface. When I paste one surface into another, the surfaces go haywire. I have attached a plan and cross section view of what the 2 surfaces (cuts) look like in relation to each other. Does anyone know how I could combine them into one surface and "trim" off the inside grading that overlaps..?
Thanks in advance for your help!
Solved by neilyj666. Go to Solution.
Your section view suggests both cut-outs daylight to elevation 5. If so, you could make a flat surface at elevation 5. Paste the smaller cut-out into that surface and then paste the larger.
You guys rock. Thank you so much for the replies. Those are both REALLY good suggestions. I went ahead and tried the "minimumdistbetweensurfaces" routine because I've never used it before. After a few trial and errors, I was able to create a polyline at the intersection of the 2 surfaces and then use that polyline to create breaklines, boundaries, remove overlapping triangles and then paste the 2 surfaces together. It looks perfect. Whew! Thanks again 🙂
If this answer solved your problem please mark as solution
All kudos gratefully received
