You can see in the attached screen cap that colors 1-9 appear as white on my screen and that colors 10-22 are not correct either. This is only occuring in one specific drawing. Is there a preference that I switched somewhere that would make this happen? I have double checked that everything is ByLayer or ByColor that I can think of. If I insert this color chart into other drawings it looks fine. using C3D 2012.
I would just restart my drawing, however it is the new company template file that I have invested many hours into and would really like to be able to keep working with it and not start over. Or is there a good way to import and overwrite all the Prospector settings into a blank drawing?
Thanks in advance!
Rafael
Rafael,
If you want to overwrite all the prospector settings, save the drawing, go to the Manage tab of the ribbon, to the far right on the Styles panel, click Import. Browse to a drawing or template file that has "good" styles and settings, and it will overwrite the ones currently there.
Yes, on the AutoCAD forum soomeone identified the switch I had thrown to cause this.
In the response above, will the Import also overwrite the "top level" Feature Settings for each group? i.e. Default Styles, Default Name, etc. ?
Thanks all for your input! That made my weekend easier! 🙂
